Where would i hook up led floor lights to come on when doors
Looking again,, no..
The 9, 15amp is circuit protection for the interior/coutesy lamps,, but is the feed in (not switched) for the control module for the interior lamps for theater/dimming mode.. You might be able to catch the GY/VT wire coming out of the panel, but will have the theater dim function.. Not sure about anysizeable or extra load added there..Might be able to add a circuit and/or relay, with the door ajar switch in control of the grounding?
catch the GY/VT wire coming out of the panel, but will have the theater dim function. What is gy/vt? Green and violet? The kit comes with wire led and a on/off switch. So how exactly do i hook it up to that spot and what will it give me?
Lisa
Aug 7, 2008 08:46 PM
