1988 Pony Fuel problem
Old Nov 13, 2006 | 11:17 PM
husk1295's Avatar
Default 1988 Pony Fuel problem
Hey Guys im new here and have a question. I bought a 1988 Pony Escrt, it has been sitting for quit a while....well anyways, i took it for a spin the other day and no i cant get it started. I poored a little fuel down in the air box and it would fire up for a sec or so. Has anyone heard of this and if so what do i need to get it fixed. Thanks in advance.
Mike
Old Nov 14, 2006 | 12:09 AM
wheelsup68's Avatar
Default RE: 1988 Pony Fuel problem
If it runs with fuel injected into air box then you have 1 of the following problems. Fuel Pump, Fuel pump relay, Inertia switch somehow became engaged.
Old Nov 14, 2006 | 12:13 AM
94 4x4 ranger's Avatar
If you have fuel in the tank you ethier have a bad fuel pump or a bad fuel pump relay.Listen for the pump when you turn the key.
Old Nov 14, 2006 | 10:07 PM
husk1295's Avatar
Thanks guys for the quick response, i figured it was the fuel pump since i dont hear it kick on when i turn the car on. Second question, where is the fuel pump? i looked by the gas tank and dint see it, also what does on cost?? Thanks guys
Old Nov 14, 2006 | 10:23 PM
wheelsup68's Avatar
Fuel pump is in the gas tank... Did you check the inertia switch it will cut off power to the pump.
Old Nov 14, 2006 | 10:39 PM
husk1295's Avatar
No i didnt where is the inerta switch located???
Old Nov 14, 2006 | 10:42 PM
wheelsup68's Avatar
If you have owners manual it should show exact location, but if I remember right it might be in trunk area mabey left side behind wheelwell carpeting, might be right side, I'm just not sure Ford had a tendency to move these all over the place. Look to make sure the red button does'nt need to be depressed. If its popped up then it will kill power to pump.
kinkyponygirl
Aug 7, 2014 06:37 PM
bugman114
Mar 7, 2012 06:58 PM
qtrhoss
Jul 18, 2010 06:47 PM
Larry607
Jan 5, 2010 11:33 AM
drw0392
Jun 10, 2006 12:49 AM
