1989 excort timing belt
Old Dec 12, 2006 | 03:41 PM
heidi's Avatar
Default 1989 excort timing belt
I have a question on the timing belt..is there a spring loaded arm to put the timing belt on?? not sure how to get on without
just streching over pully??? maybe an easy way??
Old Dec 22, 2006 | 06:18 PM
jesusjeep19's Avatar
Default RE: 1989 excort timing belt
There is a tensioner that can be moved. It is the pulley below the cam gear. There is a bolt on each side. Once you loosen those two bolts you can use a pry bar or long screwdriver to push the tensioner towards the firewall and release the tension on the belt.
NickTurbo
Apr 1, 2012 09:21 AM
FIRE RANGER
Dec 6, 2009 01:17 PM
Demps
Jun 15, 2009 11:19 AM
Demps
Jun 15, 2009 03:54 AM
Qaiphyx
Apr 4, 2008 11:59 AM
