1997 Dies out restarts when cool
Old 06-08-2018, 08:35 PM
Mike Mulback's Avatar
Default 1997 Dies out restarts when cool
Car will run fine then randomly die out then restart when cooler. Has A slight hesitation from idle.
Replaced so Far. o2 sensor, Crank position sensor, Throttle position sensor, Fuel pump, Pcm (X2). Timing Belt/water pump. No changes
Actually got more hesitation with new Throttle Position Sensor.
Seemed to stumble on a turn once or twice,and brakes might have fluttered.
Vacuum issue?
No vacuum leaks- tested with starter spray at all junctions, New Pcm is exact year model ect. Might replace Fuel pump relay
Old 06-09-2018, 08:33 AM
If you would like to get a visual picture of power getting to the fuel pump you could connect a test lite to the inertia switch secure enough so you can drive your vehicle and glance at the light to see if it falters any.
If it does, the problem is before the inertia sw. ie. fuel pump relay,PCM or wiring.
If it shows no apparent change when the problem appears, problem can be after the inertia sw on the way to the fuel pump. There is something to keep in mind and that is if neither applies , it could be the pump itself of possibly a ground connection which the lite would not show since it is placed to only show power after the sw.
Old 06-16-2018, 11:54 AM
Default UpDate
Well I brought tih car to my local shop and the lead mechanic drove it around and ALAS the car died on him. he left the car and pretty sure it was starving for fuel S we pick the car up taday see what happens
Old 06-18-2018, 11:24 PM
revengeable's Avatar
is this a 2-door or a 4-door?
Old 06-19-2018, 12:06 AM
4 door, Replaced fuel pump........
Old 06-29-2018, 12:19 PM
Default Fixed
Ended up being a intermittent fuel pump. replaced no problems
superflydgreat
06-25-2015 02:53 PM
Bherbin
02-19-2015 04:54 PM
fixright
01-18-2015 09:35 AM
ikala476
08-22-2009 08:48 PM
Larose4139
04-12-2008 06:26 PM
Quick Reply: 1997 Dies out restarts when cool
