97 Escort Losing engine coolant
Old Feb 7, 2006 | 07:58 PM
apeesue's Avatar
Default 97 Escort Losing engine coolant
I have a 97 escort that loses around a quart of engine coolant every month, I don't smell it in the vents so I don't think it's a bad heater core, and it doesn't look like it's coming out of the exhaust either, and Ford just replaced the radiator, anyone have any ideas what might be wrong?
Old Mar 5, 2006 | 08:38 PM
tonskiguy's Avatar
Default RE: 97 Escort Losing engine coolant
Definately a cracked head.
Old Apr 5, 2006 | 02:30 PM
apeesue's Avatar
We noticed yesterday that there is now water coming out the exhaust, however, it's super clear water. If it's the head or the gasket would it be spitting out clear water like that?
Old Apr 5, 2006 | 03:04 PM
waldoranger's Avatar
check the oil and see if it lokks milky. if so then you have a bad head or head gasket
Old Apr 5, 2006 | 03:27 PM
apeesue's Avatar
Just checked oil again to look for water and found a little surprise...MILKY OIL! So how do I narrow down whether it is the gasket or the head itself?
Old Apr 5, 2006 | 03:59 PM
Jeanna's Avatar
Joe are you there Jeanna
Old Apr 6, 2006 | 06:21 PM
paintedwagons's Avatar
hi, you could have a "snifer" test done on the engine coolant. this involves the use of an exhaust gas anaylizer (used in mot stations) to sniff for exhaust gas in engine coolant bottle. should show if headgasket is gone. look at the hydro carbon readings
daveshady10
Apr 11, 2013 08:19 AM
dustinc
Aug 23, 2011 06:53 PM
bonnie8183
Oct 8, 2008 09:02 PM
culater45
Jul 13, 2008 12:37 PM
hitkrdnck62571
Sep 21, 2006 11:04 PM
