97 wheel bearing??
Old Sep 22, 2008 | 09:09 PM
robcat's Avatar
Default 97 wheel bearing??
I was checking out the wifes 97 escort. A little shimmy while driving. I grabbed the front wheels while car wasstill in the ground and found a little movement when i grabbed the top of right wheel and pulled and pushed. I also noticed the outer tie rod was very loose on right side. How much movement should there be on the wheel bearing. If bearing has to be replaced, is it just a matter of changing bearing or does co,plete hub have to be changed? I am going to change tie rods.
Old Sep 22, 2008 | 09:56 PM
Default RE: 97 wheel bearing??
Changeable bearing, but a pressed in sealed ball unit.. Bearing play not to exceed 0.05 mm /.002 inch
Old Sep 25, 2008 | 09:47 PM
Sterling_Six's Avatar
ORIGINAL: Hayapower
The wheel bearing is a changeable unit...and is pressed inside the Wheel Hub....He would still need to take the Hub off...have the wheel bearing pressed out...and new one in....
I would suggest that he buy a new hub with a Bearing already in place...
While the Hub is off...it would be a great time to replace the Ball-joint, and if need be the Outer Tie Rod.
O2THPIC
Jun 11, 2009 10:10 AM
dewdog1978
Mar 10, 2008 06:02 AM
five0stangman
Feb 29, 2008 06:46 AM
applmillane
Jul 19, 2007 12:48 PM
jentner
Jun 17, 2007 11:54 PM
