Ball joint removal - 97 Escort
Old 08-20-2017, 05:59 PM
twj815's Avatar
Default Ball joint removal - 97 Escort
I'm replacing the ball joints on my 97 Escort with 160,000 miles. Driver's side came out of the steering knuckle with some effort but the one on the passenger's side won't budge.
I'm thinking about taking the knuckle off of the car and maybe applying a torch to it to get the joint out.
Good idea or bad? Alternatives?
Old 04-23-2018, 06:06 AM
revengeable's Avatar
as long as you take out the bolt holding it to the spindle it should come out as that is the only thing holding it in place. In your instance the ball joint will require extra effort. Do not try to wedge the spindle apart as this may crack it at that point. I have had luck with ones as you describe by using a hammer and tapping on the ball joint loosening it from its grip
regalone70
03-30-2009 08:06 PM
bmarnall
06-28-2007 08:23 PM
KREEKVIEW
01-02-2007 10:21 AM
64compact
11-02-2005 08:16 AM
DYI
03-28-2005 11:54 PM
Quick Reply: Ball joint removal - 97 Escort
