brakes
Old Sep 13, 2006 | 07:38 AM
mark78's Avatar
Default brakes
i recently bought a 1.8 td ford escort and the brake pedal is very hard you nearly have to stand on it to get stopped i have changed the master cylinder and the servo and still no different any one any idea of what the problem could be cheers
Old Sep 13, 2006 | 08:14 AM
94 4x4 ranger's Avatar
Default RE: brakes
[sm=welcomesign.gif]This sounds like a vacuum leak at the power booster behind the master.
Old Sep 13, 2006 | 08:18 AM
mark78's Avatar
Default RE: brakes
how do i fix that ranger thanks for the quick reply
Old Sep 13, 2006 | 08:32 PM
Default RE: brakes
First check for any vacuum hose's off cracked or broken.[hr]If that is not it take a look at the plastic check valve at the brake booster make shure it has vacuum by taking it off the booster and starting the vechile (vechile may not run)and see if it has suction if it does brake booster may be leaking if it is it need's to be replaced.
jason
Jul 21, 2005 01:10 AM
CORTINA302
Apr 11, 2005 02:22 PM
fishhead
Dec 2, 2004 12:48 AM
maiden_fan
Aug 4, 2004 03:10 PM
fishhead
Aug 1, 2004 06:23 PM
