escort runs then stops running
Hello, Hoping someone can help us out here.
we have a 88 ford escort pony that will start and runs good but after about 10 minutes shuts its off. We have replaced the feuel pump and fuel filter. we have check the inertia switch and it is on. the new fuel pump is kicking on with no problems. anyone know what we can look for? |
RE: escort runs then stops running
Is the check engine light on?
I would look at the fuel injectors, the mass airflow sensor, o2 sensors, and the coolent temperature sensor. |
hi, have you solved your problem?
I have cabrio 1994, with the same problem, when is warm, will not start. |
auto chock
