LOSING COOLANT
I have a 98 Escort ZX2 that keeps losing coolant out the reservoir. The car was cold at 5:00pm yesterday with the radiator full and the reservoir empty. I filled the reservoir to 'full when cold' and drove for an hour. The radiator was still full when hot but the reservoir had lost 1/2 the coolant I put in there. Again at 6:00am, the car was cold, the radiator is still full where it was prior and the reservoir is now 3/4 empty from the cold line. There does not appear to be a hole in the reservoir. Does anyone have any idea what would cause this to happen?
ORIGINAL: bonnie8183
First do you see any murky white beige color sludge in the oil dip stick??? If you have this you have a Head Gasket leak...or ....Head gasket crack...Block crack...etc....Is there any Anti freeze leaks on the ground...driveway...etc??? Check the Radiator for leaks....
Get back to us on this [8D]
97, 98, antifreeze, coolant, empty, escort, expedition, f150, ford, full, losing, radiator, ranger, reservoir, thunderbird
