Moisture inside the headlight of my 98 ZX2
Does anyone know how to replace the headlight on a 98 Escort ZX2? Mine is getting moisture inside and needs replaced. But it looks like you have to remove the bumper cover to get at the bolts to remove it. Does anyone know the correct way to replace the entire headlight
RE: How to replace the headlights on an Escort ZX2
First look behind the headlight and unplug the connector right behind it.
Now turn the access cover counterclockwise to get to bulb............ http://img207.imageshack.us/img207/8407/1cy1.gif Disconnect the connector from the bulb by pulling rearward. Rotate the headlamp bulb retainer one-quarter turn, counterclockwise and remove the headlamp bulb from the headlamp by pulling it rearward....................... http://img207.imageshack.us/img207/1379/2na6.gif Hope this helps :) |
Thanks for the help mulletman. But what I'm really looking for is how to replace the entire assembly. Mine is leaking and getting moisture buildup inside and I want to replace it.
