-   Ford Escort (https://www.fordforum.com/forum/ford-escort-29/)
-   -   oil in coolant (https://www.fordforum.com/forum/ford-escort-29/oil-coolant-7974/)
vesmcd Apr 23, 2007 04:58 PM
oil in coolant
My GF's '95 Escort is starting to get oil showing up in the coolant reserve tank, but NO coolant in the oil. It's a 1.9/5spd,156k mi. My first guess is bad head gasket, but before I pull the head, anybody got a better idea.
elementx440 Aug 1, 2007 08:09 PM
RE: oil in coolant
my grandfather used a coolant bottle that I filled with old motor oil, to top off his radiator. ooops. would your GF do such a thing...
someone once put steering fluid in my master brake cylinder. that sends your pedal to the floor, quite scary.
anyways. probably the head gasket, warped head? has it overheated?
FordNutz Aug 2, 2007 05:53 AM
RE: oil in coolant
Had a brother who's tranny fluid and coolant were swapped when his radiator failed internally on his automatic GMC Jimmy in 83'. Tranny oil is cooled via routing it through the radiator in its own sealed environment.
vesmcd Aug 2, 2007 10:41 AM
RE: oil in coolant
My GF doesn't put anything in the car except gas.It's an Escort and a woman drives it,of course it has overheated. It eats fan relays but she always trys to "make it homeso it's easier for you to fix".[:@]
I pressure checked the system(no leaks),flushed and refilled. So far no moreoil. I got no clue. Guess I'll just let her drive it and wait.
wheelsup68 Aug 2, 2007 08:26 PM
RE: oil in coolant
Probably the head gasket, I got a low mileage Neon that was doing the same thing. Pulled the head and found corrosion pits on head surface from where the coolant was never exchanged on 10 year old car. Pretty important to do so as it will become ery acidic. Element had a good idea, if only the car was not a 5 speed.
daddyblaize Nov 19, 2018 06:00 AM
Oil And Coolant Contamination
daddyblaize's Avatardaddyblaize , Today 01:27 AM
I've been slaving over a 2003 Windstar for months.... working every weekend to replace an engine with a salvaged engine transplanting bits from the old onto the salvaged engine. I freshened the newer engine with new timing set, oil pump, water pump and crank and cam sensors. After completing and test driving, the next day found milkshake on the dipstick. I suspected the front-cover gasket, so I'm removing and resealing. I'm recalling I bored out the crank snout while accidentally using the wrong sized harmonic puller--not badly enough that the harmonic bolt couldn't be used so I ignored it. I'm wondering if a slightly damaged crank snout could lend itself to such as oil/coolant contamination?
