Timing Belt Question 1st Gen
Old May 11, 2005 | 03:40 PM
DRLM002's Avatar
Default Timing Belt Question 1st Gen
Hey Everyone!Heres my problem.I have an 1987 escort gt 1.9 efi ho with apx 180000kms.My timing belt broke as i was pulling into my drivewayD'OH.At least i avoided towing costs.Anyways i refered to my hanes manual,pulled out the starter, timing belt cover,altenator,You know the usual when i came to the pully.Hmmmmm the manual says to simply put a screwdriver in the flywheel.No problem.then remove the bolt from the pully.Well theres apx. .5 of an inch at most clearence.The only thing i can see is to drop the motor mount on that side.My question is this correct,will dropping the mount do harm?If anyone knows Id appriciate it.THANKS
Old May 11, 2005 | 07:21 PM
cctxfish's Avatar
Default RE: Timing Belt Question 1st Gen
You are going to need an engine lift. remove the front engine mount and lower the engine past fender well. You don't need a screw driver in the flywheel if you have an impack wrench. And you may need a puller to get the crank pulley off.
Old May 12, 2005 | 01:02 AM
DRLM002's Avatar
Got it!Everythings back together and started first crank!WAHOOOO!!!Thanks for the help.
Old May 12, 2005 | 01:50 PM
cctxfish's Avatar
GREAT JOB! a timing belt isn't the easiest thing to do for a DIYer
Old Aug 28, 2007 | 07:33 PM
covington's Avatar
I am replacing the timing belt and water pump on a 94 escort with the 1.9. I got the water pump off fine and the timing belt is off everything except the bottom (crank) gear. My Haynes Manual says to wedge a screwdriver also. The only problem isI have no clue what/where to wedge it. The manual has no illustation or or explanation on doing this. It just says to do it. I have looked everywhere for a place to wedge a screwdriver and have found nothing. please help
NickTurbo
Apr 1, 2012 09:21 AM
FIRE RANGER
Dec 6, 2009 01:17 PM
Qaiphyx
Apr 4, 2008 11:59 AM
bud fox
Oct 25, 2007 06:30 PM
philly
Apr 29, 2006 09:58 PM
