myndsai |
10-21-2010 10:36 AM |
ZX2 run rough, choking out, replaced coolant temp sensor and ran great for an hour
Hey everybody! I posted yesterday about my ZX2, but went and had codes read....:(. I had been having problems with the car choking out and smelling like fuel. I changed several things such as spark plugs, air filter, pcv valve, ignition coil...with no change in operation. Then I changed the coolant temp sensor yesterday, and the car ran great for about an hour....then started choking out again and died when I got home and hit the gas in the drive way. Now I am having the same problems again. I took to Advance Auto and they read the codes. They are as follows: number 1 misfire, number 4 misfire, crankshaft sensor (A or bank 1, or single cylinder), mixture too rich.
I think I have the translation right. I never had the cranshaft sensor code before...that is something new. I am wondering if the crankshaft sensor reading is a false reading, because of the mixture being to rich and the car operating funny. If the sensor reading is true...i think I know what that entails, and it probably means the car is done for me....Any info would be appreciated. Thanks!
