2000 ac problem
Old Jun 8, 2008 | 11:36 AM
ups88's Avatar
Default 2000 ac problem
have a 2000 excursion with a a/c problem. checked freon level -fine,checked fuses in both boxes-fine,checked for juice at the a/c clutch with tester and no 12v. any ideas on this? thanks
Old Jun 8, 2008 | 11:41 AM
david paul's Avatar
Default RE: 2000 ac problem
check ac relay and low pressure switch
Old Jun 8, 2008 | 12:54 PM
ups88's Avatar
would the ac relay be the one in the power dist. box? where would the low pressure switch be located? what is the best way to test these? thanks
neford
Sep 21, 2018 03:44 AM
afloyd
Oct 23, 2006 11:18 PM
leo_clarke
Jan 16, 2006 02:29 PM
Roanbadger
Dec 20, 2005 03:40 PM
bwilson3
Oct 9, 2005 02:41 PM
