Ford ExcursionSo the size of the Expedition is not enough for you, then the massive Excursion is the way to go. With options including a powerful diesel engine, the Excursion is like a tractor trailer built for family use.
2001 Ford Excursion 2WD 6.8L V10. Has 3rd row seating. Exterior very clean NO RUST! NO DENTS! Paint fading a bit on roof. Interior in good shape also except driver and passenger captains seats have heavy wear and tearing in leather. Using cheap seat covers (See pics). 247000 miles. Runs great. Looks clean. NO LEAKS! Truck got it's oil changes every 4 months. Took very good care of it. Pulled many campers fully loaded with 4 kids and 2 large dogs over the years. Great family vehicle. While it has no 4WD makes it much easier to work on with no front drive axles, transfer case, etc... to deal with.
Updates: Fresh oil change this week New power steering pump Newer IAC valve Newer PCV Newer TPS Newer aftermarket slotted front rotors Newer tensioner pulley and idle pulley Newer plugs (double lridium), boots and springs Newer Wheel Bearings Inners & Outters all the way around Trans rebuilt with less than 15,000 miles on it Aftermarket rear sway bar Aftermarket adjustable shocks AirLift rear airbags (brand new in April)
Known issues: - 1 pesky coil pack that miss fire on initial startup when humid (after rain, after snow or after sitting for extended periods) goes away after warmup and moisture burns off motor. - front seats have extreme wear. Using seat covers. - rear doors and hatch do not lock with power locks - only one key, has alarm but never had a keypad to use it - rear windshield washer line leaks fluid - was in an accident with prior owner, so rear passenger window was replaced and tint doesn't match. - AC works on low, but doesn't get cold on high might need some work to figure that out. - rear-view mirror has a dark cloud but never used it.
That's everything I can think of. Honest Sale. To come see 586-330-0833.
