braking causes pull to the left
Old 10-19-2010, 02:43 PM
lgunnarson's Avatar
Default braking causes pull to the left
I have a 2001 excursion V10 with 51,000 miles. It recently started pulling to the left. My mechanic has been throwing parts at it including new calipers on all wheels, new front brake hoses, new front pads, turned front rotors. It will pull you into the left lane in about 120 yards if braking at 60 MPH. It is real bad when pulling my travel trailer. All the ball joints were inspected and said to be fine. Tires were rotated - no change. Alignment is perfect. HELP!
Old 10-19-2010, 08:48 PM
Can you get the answer to this next question without ruffling the mechanic's feathers?
Did he replace the calipers only or did the calipers get replaced with new sliding pins.
If he didn't remove and clean and lube the caliper pins , the left front brake may be doing more of the braking work. It is only a consideration at this point.
Old 10-28-2010, 09:26 PM
enibum's Avatar
It also makes me wonder if there is air in the line on the right side.
Old 11-04-2010, 09:01 AM
lgunnarson's Avatar
The third repair shop I took my excursion to solved the problem. The lower left ball joint was absolutely shot. I had all four replaced. Very disappointing that I asked both of the previous mechanics to check the ball joints. They both told me they were fine. I now have all new rotors, calipers, brake pads, hoses, etc.
Old 11-04-2010, 09:39 AM
Don't feel bad, at least one person knew what they were doing. Depending on where you drive , the other ball joints won't be far behind, expect it!
Old 09-23-2012, 08:19 PM
David Lee's Avatar
Default braking causes pull to left
Is this a common problem with X's. I know of 5 including mine that does this. Mine doesn't have stock front and rear ends. It has been lifted 22' and has dana 60 & 70. The tie rods are wore out for sure and will be replaced next weekend.
crispyc21
03-10-2013 08:17 PM
New2Ford
01-07-2009 06:56 PM
l2rocku2
01-05-2009 11:30 PM
thunderbirdgreent
07-14-2007 12:58 PM
fasttalker
11-30-2005 09:32 AM
Quick Reply: braking causes pull to the left
