engine dont run... 6.0 powerstroke
Old Dec 7, 2007 | 11:26 AM
  #11
Default RE: engine dont run... 6.0 powerstroke
Fuel control module is on the left frame rail, below the drivers position.. Pump pressure should be 45-58lbs or so...
Old Dec 7, 2007 | 02:02 PM
  #12
BRETM's Avatar
The correct place to check the fuel pressure is at the secondary fuel filter housing next to the oil filter, but requires special adapter to do it. But I would not be worried about fuel pressure as much as oil pressure. I would suspect the STC (snap to connect) fitting on the rear of the high pressure pump or the branch tube in the block is leaking. Has been known concern on the 05-06 trucks and vans.
Old Dec 10, 2007 | 02:28 AM
  #13
bonboy's Avatar
yes i suspect this..... today i start to put out this element.....
neuma181
Mar 16, 2014 09:34 AM
swampbilly
Oct 3, 2011 09:50 PM
Laura W
Sep 21, 2010 08:33 PM
mwx4mwx4
Feb 8, 2009 06:42 PM
