Troubleshooting 4wd
Old Mar 14, 2021 | 11:29 AM
Jbeam's Avatar
Default Troubleshooting 4wd
I’ve searched and can’t find a solid answer. I’m trying to get the 4wd working on my 2001 excursion. I unbolted the shift motor from the transfer case and jumped the BRN/WH wire to verify it moves and the ORG/LB wire to verify it moves and it does. Now I can’t get the correct position on the motor to put it back on the transfer case. What do I need to jump to get back to 2wd high?
6.8 v10. Dash switch does nothing and 4x4 light shows briefly on startup.
1Dozerdawg!
Feb 3, 2021 02:53 PM
Shelbygt500
Jan 21, 2016 01:21 PM
mdh
Mar 14, 2008 09:42 PM
JCAR
Oct 14, 2007 11:22 AM
jcarini
Apr 1, 2007 07:09 PM
