What to look for in buying a 2000 to 2004 Excursion
Old Feb 25, 2017 | 02:54 PM
ScottyGunn's Avatar
Default What to look for in buying a 2000 to 2004 Excursion
Hi all,
I'm considering getting a larger SUV than what I have. The Excursion seems to have what I'm looking for in terms of size and price range.
What are some things I need to look at before I buy? Mostly, the gas models, 10 cylinder, are what I'm seeing in my price range but I did find one diesel 7.3 in my range.
I will be towing some heavy items, so 10 cyl or diesel would be good.
Thanks!
Old Mar 2, 2017 | 11:07 AM
Thumbs up
Missed your post..
The V10 makes decent power, sound awesome too, but fuel mileage would be 'much' less than a 7.3.. If your planning towing heavy, and often, I'd look for a lower mileage 7.3. Id also go low mileage/newer if possible.. Very easy to add extra power to a 7.3,as well. A V10 probably wouldn't disappoint other than mileage, a bit cheaper to maintain over a diesel, so depending on the weights you'll pull, grades and distances, fuel numbers may be a factor. My 02.
LOVES VANS
May 5, 2015 05:04 PM
MetalMatty
Apr 1, 2015 08:59 PM
Bikeman
Dec 23, 2012 10:49 AM
blacksmoke91
Nov 18, 2011 09:53 AM
jimsexcursion
Apr 17, 2008 05:29 PM
