1998 Expy 5.4 Plugs
Old Sep 18, 2007 | 07:39 PM
fitter1974's Avatar
Default 1998 Expy 5.4 Plugs
Just wondering how bad it is to change out the spark plugs on the 5.4L expedition, not real sure about the coil packs and if there are any special tools needed, not sure if these plugs have ever been changed, truck has 96k on it. Thanks for your help!
Old Sep 20, 2007 | 01:56 PM
FordNutz's Avatar
Default RE: 1998 Expy 5.4 Plugs
I've changed all the plugs on my 01 superduty and its not too bad. Just have to unscrew the screws holding the feul rails on to make getting the coil packs off easier. Just prying up on the rails gentlywill get them to pop up. sometimes the feul injector stay with the rail, sometimes not, but no problem. Coil packs are held on by a screw and they slip out with the long boot attatched. Unplug them from the wiring harness first. Then its just the pain of using an extention just long enough to give you room for a ratchet. I kept a shopvac close to keep anything from falling down into the holes. Just be careful when putting them back in not to cross thread them---seriously. Use what the manual calls for in a plug, platinum type. I used Autolites because of friends advice. Bosch is overrated from personal expirience, and since its a ford god forbid you use a champion plug, heard that one from a man at the dodge dealer. My new plugs @ 88k have run perfect and i'm at 96k now. But It's near enoughfor you to change em out. The expedition is like the f150 setup i believe, and the drivers side has something in the way, not sure what they said it was, but it's a tough job sometimes getting it out of the way. These same guys pull motors on these trucks and leave the cab on the truck.
Good luck
Old Sep 21, 2007 | 05:35 PM
fitter1974's Avatar
Thanks for your help!, I know its going to be a pain, just another one of fords great designs! Also has anyone ever used Royal Purple synthetics? heard lots of good things about them.
Old Nov 19, 2007 | 10:52 AM
mister_v_man's Avatar
The procedures for replacing/changing spark plugs on the Ford Expedition, Lincoln Navigator, & F-150 Triton.
I just replaced my spark plugs on my 1998 Ford Expedition. It was much harder than I'm used to (I have a 1989 Jeep Cherokee with the inline six, and I can change the plugs on that in about 10 minutes).
Anyways, I've outlined the procedures that I used. Don't rely on a store-bought repair manual as the instructions are way too vague.
Here are the instructions verbatim. If you want the instructions with photo examples just follow the link at the bottom.
Hope this helps,
V
I just finished up replacing the spark plugs on my 1998 Ford Expedition with the 5.4 Triton V8. (This was a pain in the @ss; I owned a 1990 Ford Thunderbird and I thought those were horrible). Anyways, after searching the internet I found some very good tips on several site forums. I used these tips along with some additional steps that I thought would definitely help make the task less stressful. The additional steps may seem extensive, but they help make the task much easier, and like I said, LESS STRESSFUL!
First off, don't bother relying on a store-bought repair manual like the one I own. The instructions are so vague, they pretty much just tell you to remove the coil packs and remove/replace the plugs.
The best method involves using a foam pad (or thick padded carpet) and setting it over the radiator and top of the engine. You'll need a stool or chair to secure your footing while lying across the engine bay on this.
You will need a good assortment of extentions and swivels in 1/4" & 3/8" drive if possible.
If done correctly, it should take between 1-2 hours.
First as usual, disconnect the neg. on the battery.
Lay the padding across the radiator/engine bay.
When doing this job you'll end up looking kinda like this.....(I recommend using something much more stable than this little stool I used).
Remove the plastic cover covering the throttle body. (Three 10mm bolts)
Remove power connection terminal cover on the passenger side near the battery (this pops off when you pull downward & out at the bottom of it)
Remove three 13mm nuts and the cables. (make sure you mark them so you put them back where they were). Next, remove the two 8mm bolts holding the entire assembly to the firewall. Pull away from the firewall. Now you will be able to have easier access to the #1? spark plug farthest back on passenger side. I feel that this is the hardest one to change.
Remove the three 8mm bolts & remove the plate that secures the power steering reservoir in order to access the #5 spark plug.
Replace each spark plug one at a time. On the driver side you may need to remove the two 8mm bolts securing the fuel rail. You may need to pull the fuel rail up and away slightly to clear the check valve and access the #6 spark plug. Make sure you blow away all debris before removing the fuel rail. You do not want anything falling into the manifold. This would be HORRIBLE! Also, only pull the fuel rail away as far as neccisary to access/remove the bolt securing the coil pack and the coil pack itself. Debris (or a dropped coil pack bolt)could possibly fall into the manifold through the injector ports! Again, this would be HORRIBLE!
Attach a small section of hose to reach the hard-to-reach areas. You need to blow out the spark plug holes BEFORE you remove the plugs to prevent debris from falling into the cylinders. And yes, this would be HORRIBLE!
Also, make sure you coat the spark plug threads with anti-seize, and coat the inside of the boots with dielectric grease. This will prevent corrosion, heat damage, and prevent the boots from sticking on the next replacement. Gap the plug to specs before installation.
After taking your time and being patient, you will find yourself finishing up this job and feeling a great sense of accomplishment. Bolt all parts back up to where they were, and re-check all of your connections to include connections to the coil packs, injectors, and also inspect surrounding vacuum hoses to see if they were accidently disconnected when moving them around to access the spark plugs (the PCV valve kept popping out when I did mine).
Hinesight is always 20/20, but I'm pretty sure I could do this again in under 1 hour. Remember, take your time, be patient, be careful, and take a breather if you need it!
Enjoy,
Vic
here's the link to my web page with accompanying photos:
http://www.angelfire.com/sd/vmkramp...lug_change.html [/align]
SAMF
Nov 21, 2007 07:57 PM
oregonn8v
Feb 14, 2007 08:14 PM
mi97tbird
Nov 27, 2005 07:27 PM
Kucimat
Sep 15, 2005 09:06 PM
carebear3030
Jul 21, 2005 10:11 PM
