Shift Lock
Old 12-16-2010, 08:49 AM
jrntn's Avatar
Default Shift Lock
I have a 2007 Expedition and the shift lock switch isn't releasing everytime I step on the break. I read the owner's manual and it mentioned the rear break lights. Sometimes they come on and sometimes they don't. So, when the lights don't come on, the switch doesn't release the gear shift. I keep pumping the peddle till the lights come on and then the shift lock switch will release the gear shift and I can move it out of park. I tried checking fuses and couldn't find any blown. Any advice?
Old 12-16-2010, 12:15 PM
As you already know the brake switch also releases the shift interlock. More than likely the switch either may need to be adjusted or the switch is on it's way out. They aren't very expensive compared to not being able to get out of a place and get going.
It might be a good idea to check for a loose connection at the switch itself before going out and getting another one.
Old 12-17-2010, 03:23 PM
jrntn's Avatar
Thanks Hanky,
I took a look at the switch. Removed it and reset it. It now seems to work. Must have worked itself loose a little I guess. Thanks a bunch.
Old 12-31-2010, 05:43 AM
offroad44's Avatar
That happened to me a few times, i messed with the switch and then it worked. The last time I could not get it working so I had to change it.
If you have to change it buy it from ford, I bought the first one at advanced auto and it was a no name switch for less then half the price of the ford switch but it didn't work, drove me nuts untill the guy at ford told me that happens alot with the cheap switches
BelowJon
07-02-2008 08:57 PM
jon0249
04-08-2008 01:09 PM
Zoo Mob
04-06-2006 09:05 PM
jpbucher
03-04-2006 06:44 PM
Mobile AV
08-17-2005 04:01 PM
Quick Reply: Shift Lock
