2018 Expedition leveling suspension
Hi! How can I tell if my 2018 Expedition is equipped with automatic leveling suspension? I have looked a the website, owner's manual and window sticker with no luck. It is a Limited model with everything, including the heavy duty tow package.
Thank you!
Thank you!
Welcome to the site..
I'd imagine it would have been on the sticker..
But, to quick check you can look from the rear,, on the lower suspension arms fairly close to the inner attaching/pivot bolts you would see the height bracket bolted to the suspension arm, with a rod extended upward to the ride height sensor mounting plate
Same with the fronts, only the sensors on the control arm mount, and the arm extended to the upper suspension arm...
