fishfun83 |
02-12-2009 09:28 PM |
Bad Catalytic Converter
Last week, my 1998 Ford Expedition with 163,000 miles started running rough going to work. When I got home I put my OBD on it and it showed 2 fault codes. One code was a bad oxygen sensor, and the other was a misfire on cylinder 6. I had recently replaced all of the coils and plugs so I only replaced the plug in the number 6 position and also replaced the bad oxygen sensor. The Expedition still ran rough. Being frustrated, I took it to my local mechanic. He is claiming, after replacing 2 more oxygen sensors, ($500) that my converters are plugged and wants an additional $2,000. Folks at work are saying if the coverters are plugged, it would be a gradual decrease in performance and not start missing all of a sudden. What do you all think? Could it just be a bad fuel injector on cylinder 6? Maybe a bad coil on 6? I would appreciate your thoughts.
