-   Ford Expedition (https://www.fordforum.com/forum/ford-expedition-21/)
-   -   Brakes are locking up (https://www.fordforum.com/forum/ford-expedition-21/brakes-locking-up-37603/)
Omar OneDouble Martinez Mar 13, 2018 03:33 PM
I have 2007 Ford Expedition my brakes are locking up on me when I press the brake pedal and I release the brake pedal the pedal function is fine I find out when I'm at a light when I go to drive off I feel the brake still holding on to the calipers I've changed brakes calipers and discs I also change the booster and master cylinder I'm still having this issue can someone please help me
hanky Mar 13, 2018 05:35 PM
I believe I made some suggestions in your other post.
In response to this one sometimes a brake hose will develop a flap inside and prevent the caliper from fully releasing.
Omar OneDouble Martinez Mar 13, 2018 05:43 PM
Its happens to all 4 wheels
hanky Mar 14, 2018 03:48 AM
Something you might check, make sure the rod from the brake booster and pedal is not too long preventing the master cyl from coming all the way back to the released position.
amesgang Jan 31, 2022 06:20 AM
Master cylinder adjustment
Try loosening the master cylinder mount a couple of turns and test drive, if this helps then the brake pedal rod is too long you will need to adjust it.
