Death Shake
2001 2001 Ford expedition Eddie Bauer all-wheel drive Death shake temporarily after hitting a pothole on the interstate if you slow down it will stop .Replaced u-joints in front axle & rear axle ball joints pitman arm & idler arm tie rod ends .upper & lower control arm,and tires cannot figure out what is causing this shake does not do it all the time just sometimes like I said when you hit a pothole it will shake violently until you slow down it will stop you can then proceed and drive as fast as you like and will never do it again until a few days or months later please help
Welcome to the site..
OE size tires? Alignment, balance checked? |
