-   Ford Expedition (https://www.fordforum.com/forum/ford-expedition-21/)
-   -   engine noise? (https://www.fordforum.com/forum/ford-expedition-21/engine-noise-1802/)
Michele Sep 14, 2005 06:20 PM
engine noise?
Guys - I have this bizzare noise coming from my driver's front right. I have a 5.4L 2001 and it sounds exactly like a JetLiner landing! It is constant except for the pitch. The pitch changes as the accelerator is depressed?
Any ideas?
techmanbd Sep 14, 2005 06:52 PM
RE: engine noise?
Did you put any mods on it for intake? Sounds like the throttle body area. Check around to make sure all the hosing for the intake are on properly.
If you happen to put a throttle body spacer then you will get that noise.
Michele Sep 14, 2005 06:59 PM
RE: engine noise?
No, the car is stock, but I will check the hoses to the throttle body. Thanks!
cctxfish Sep 15, 2005 06:56 PM
RE: engine noise?
heard of 2 things;
1. IAC valve making noise. &
2. MAF sensor making noise. good luck
stang99x Sep 16, 2005 01:34 AM
RE: engine noise?
I'd put my money on the IAC valve
pakus Sep 16, 2005 07:41 PM
RE: engine noise?
MAF has no moving parts and can not make noise unless something has passed the filter and entered the sensor
hockeyhitman69 Sep 17, 2005 01:32 PM
RE: engine noise?
tap on the iac is probably sticking,common problem
cleaning mis only a temp fix
stang99x Sep 19, 2005 12:30 AM
RE: engine noise?
CHange the IAC valve and you'll be on your way
cctxfish Sep 19, 2005 05:26 PM
RE: engine noise?
Pacus I agree, but some say it make noise. My money would be on IAC[sm=lockeddance.gif]
Michele Oct 3, 2005 04:51 PM
RE: engine noise?
Uh, IAC is short for...?
