Ford F150 & Expedition Front Hub and Bearing Replacement
In this video I go over another common failure on the Expedition and F150 4WD vehicles. The hub and bearing on these units usually fail silently and go unnoticed until the wheel is literally binding and scraping upon turns ready to fall off unlike the explorers and FWD cars that have sealed bearings which have a loud humming noise when they are failing. I show you how to replace it with all the tips and torque specs along the way.
hi there do you have a video on a 06 ford escape wheel bearing knuckle hub ?
Originally Posted by makuloco2000
(Post 89833)
http://www.youtube.com/watch?v=NcNxBq_Wy6g The bearings for these vehicles can be found on our website OEM Ford Parts & Accessories | Lakeland Ford Online Parts... The bearings for the 2004-2005 F-150 with the base payload package is part number 4L3Z-1104-AB (#4L3Z1104AB: Hub & bearing). I can find any of these hubs, just message me with your VIN number. |
1 Attachment(s)
Originally Posted by nickfromboston
(Post 96209)
Unfortunately I do not have a video but I did attach a diagram that may offer a little help. If you need part numbers for your front knuckles I have listed them below. If you need step by step instructions you may want to try All-Data DIY. RH: 5L8Z-3K185-BA (#5L8Z3K185BA: Knuckle.) LH: 5L8Z-3K186-BA (#5L8Z3K186BA: Knuckle.) |
