-   Ford Expedition (https://www.fordforum.com/forum/ford-expedition-21/)
-   -   Fuel Pump (https://www.fordforum.com/forum/ford-expedition-21/fuel-pump-17110/)
APS612 May 18, 2009 12:31 PM
Fuel Pump
2001 Expedition: is the fuel pump located in the fuel tank? If so, is the only way to change it by dropping the tank? Thanks
APS612 May 19, 2009 11:10 AM
Fyi
Well the fuel tank is mounted under the drivers side inside the frame rail just in front of the real axle. There is a space just above where the fuel pump is located and I am not yet 100% sure if the fuel pump can be pulled out without lower the tank. I have raised the body a few inches and have the ring holding the unit in place loose so far. I will repost more information when I find out this evening just in case anyone else should run into this same issue.
APS612 May 20, 2009 10:34 AM
Fyi
Well yes the tank needs to be dropped. There are 3 straps to be released. Drop down the rear end of the tank with a floor jack or something and you can remove the pump. This should qualify to be on the "Dirty Jobs" show.
Hayapower May 20, 2009 01:52 PM
If your lucky enough, the tank hadn't been just filled either ;)
