Just wondering
Old 07-18-2018, 04:50 PM
Mbc's Avatar
Mbc
Mbc is offline
Default Just wondering
Is there any way to test a suspension solenoid on a rear wheel of a 07 expedition 2wd
Old 07-18-2018, 05:28 PM
Yes, there is !
There are at least 3 electrical checks you can do if you use a volt/ohmmeter .
The first would be to check if the ground connection is good.
The second would be to check if power (usually 12 volts) is getting to it when it is supposed to operate.
The third would be to check for continuity (specific ohmmeter reading) across it's terminals.
Then there are mechanical checks to check
If the solenoid is supposed to allow air pressure to pass when activated, you might hear it operate, but not open the passage to allow that air to pass. Confirmation needed.
And the reverse also needs to be confirmed, is it supposed to allow air to pass, then when activated prevent air from going through.
A lot depends on the application and what it is suppose to do.
This may not answer your question specifically, but if you know what is supposed to happen the above info should provide some type of guide.
Old 07-19-2018, 08:41 AM
Mbc's Avatar
Mbc
Mbc is offline
Default In appreciation
Thanks hanky. I appreciate all the info.
newjerseyjohn
05-21-2013 08:21 AM
gravis346
09-08-2010 07:57 PM
marvin1987
06-21-2009 10:59 PM
forsan
03-02-2007 11:32 PM
budlight
02-02-2007 02:25 PM
Quick Reply: Just wondering
