easoueidi |
04-20-2010 08:59 PM |
Stereo and Auxiliary Audio input problems after jump starting.
Hello
I jump started my 2007 Ford Expedition Limited per the owners manual instructions and immediately following noticed the following problems:
- the AUX button no longer showed LINE INPUT as an option. It only shows SAT 1, SAT 2, SAT 3, and RSC ? (whatever that is).
- the Volume, Media, and Preset Radio Station button on the steering wheel also no longer respond
- the CD player gives me the CD ERROR message. When I press CD, it will say INITIALIZING for a few seconds, but does not work. Also, I have at least one disk in the 6CD changer that will not eject or play. When I start the car, the disk changer makes noises like it is trying to load or change disks, but nothing happens.
I have checked all the fuses at the Power Distribution Center and Fuse box. (Right front passenger and under the hood), but they all show to be good. I have also disconnected the positive terminal on the battery for 5 minutes and reconnected, but again no changes. Can anyone think of a solution, PLEASE?
BTW: I still have an extended full warranty through Ford. This should be covered, right?
