turn signals
Ok, when i activate the turn signal only the rear comes on, and comes on at a very fast speed
nothing on the dash, mirrors, front, only the rear and very fast..... Any suggestions?? it does not do it every time........Thanks........Ed |
RE: turn signals
In most cases a double flash indicates burned out brake bulbs but....!
The multi-function switch (turn/hi-beam/wipers) is a very common problem with those and can give you those symptoms. I'd go the cheap route first by replacing the front bulbs and seeing if it starts working. If not go get a multifunction switch at the dealer(about 160.00) |
RE: turn signals
Thank You. i will give the bulbs a try first, but knowing my luck it will be the more expensive of the 2. Murphy lives in my spare bedroom!!..hahaha
