Upgrade rear shocks
Old Feb 28, 2008 | 10:55 PM
mikegigabyte's Avatar
Default Upgrade rear shocks
I have an 03, independant rear suspension. I have an atv carrier that fits into the receiver hitch. When loaded it drops the suspension around 5 inches. The tires are aboput 2 inches away from rubbing the metal. I also have tires that stick out 2 inches so it hits the fender over sharp turns when going into a ditch. Ive put in solid rubber coil spring wedges and they help lift it back up about 5 inches but its more of a temp fix. Is there something easy to install on that type of setup. Maybe air bags or ive seen an airbag inside the coil springs, something that I can have the stock ride when needed. Also not too expensive and maybe something I can install. If you can provide websites or brand names that would help.
________
COLORADO DISPENSARY
Old May 5, 2009 | 11:18 AM
ljcorby's Avatar
where did you get the coil spring wedges? How are these compared to the "coil spring spacers"?
Old May 13, 2009 | 11:03 AM
higherlp's Avatar
Thumbs up Air Bags
There are many diffarent way we can go with this.I can sit up up with a air unit that will help out a lot.website www.higherlimitsperformance.com or call 360 773 3589 and i will look up the part numbers for prices i need year make model My name is RYAN @Higher Limits Performance Thanks for time
djripper
Apr 26, 2020 10:32 PM
EFfalconsrule
Apr 10, 2013 05:26 AM
hfb1957
Jun 25, 2009 07:48 AM
arosen999
Aug 23, 2007 01:54 AM
PartsHookUp
Nov 29, 2005 08:22 PM
