-   Ford Expedition (https://www.fordforum.com/forum/ford-expedition-21/)
-   -   windows stop working (https://www.fordforum.com/forum/ford-expedition-21/windows-stop-working-27078/)
john382002 May 14, 2012 08:49 PM
I have a 06 expedition,all my windows stop working.I have replaced the main console,checked fuse,replaced circuit breaker but still no power is gettint to the main console.none of the other window switces work either can someone tell me what i have not tried i took door panel of to check for pinched or bad wires but found no faulty wiring please help me its taking a toll on me having to run a/c all the time
bluewind May 16, 2012 12:55 PM
I think you will need to use a voltage tester to find out where the problem is. I would look if there is power to the main switch on the driver's door. If no go back to the fuse panel. If there is no power the problem is between the battery and the fuse panel. Get a wiring diagram.
john382002 May 17, 2012 06:11 AM
windows stopped working
i have tried to locate wiring diagram for the windows but no luck there is no fuse panel under hood nothing but a fusable link i do notice that the circuit breaker for the windows is always hot to touch i dont know if thats normal
bluewind May 17, 2012 11:24 AM
No it shouldn't be hot. There is a fuse panel under the dash. You will probably learn how to do a voltage drop test. Google for that. The Haynes manual has wiring diagrams in the back.
supra88 May 29, 2012 07:25 PM
My truck was park for a month and 3 windows stop working, i check switches, fuses,relays,
they all good the solution was to hit every motor with a hammer and they all work again ,
yes i have to open the door panels
