wiper fluid line replacement
Hey all..
Anyone have info on replacing the line that feeds the wiper fluid to the rear wiper? My expedition leaks pretty quickly, just below the passenger side door. When I do fill it, the front gets fluid for a little while, the rear gets none, and within 20 minutes it is empty from leaking out. I can't see the actual leak or hole in the line as i haven't started to look yet, wanted to see if there are any visuals or instructions before I start just poking around. Thanks! John |
found disconnect hose and fixed
You have to move aircondinser out of the way just slied it of the metal bracket then you can fit yout hand In and reach the two hoses ones an L shape and a straight line and put them back together if that's not the one you have to take the radiator resavor off and move it to the side and then you can get to the rest of the connections dont disconnect radator lines or air condencer lines will have to refill both and get freezer burns. Gope this helps ;-)
wanted to share pix to
http://www.google.com/imgres?imgurl=http://img198.imageshack.us/img198/3594/img3511dm.jpg&imgrefurl=http://www.myfordfreestyle.com/forums/viewtopic.php?f%3D5%26t%3D4138&h=1704&w=2272&tbnid =5j3yxcrssDZvIM:&zoom=1&docid=teD8nEgj7QbtWM&ei=qA jAVLmFBIinggTSp4L4Dw&tbm=isch&client=ms-android-metropcs-us&ved=0CCYQMygJMAk
