1999 Ford Explorer start up trouble
Old Oct 9, 2006 | 10:26 PM
mystiquegoddess's Avatar
Default 1999 Ford Explorer start up trouble
So last week or so I noticed a slgiht hesitation on the start up and today it took several attempts to finally get it going. I'll have the battery checked again but last I checked it was good and charging fine.
Any other reasons for the the start up hesitation?
Old Oct 9, 2006 | 11:23 PM
94 4x4 ranger's Avatar
Default RE: 1999 Ford Explorer start up trouble
Is it the starter that has a hesitation? [hr]Or the engine firing over?
Old Oct 9, 2006 | 11:34 PM
I guess its the starter that has hesitation. When I turned the key it cranked then took some time to fully kick it.
Old Oct 9, 2006 | 11:49 PM
I would start be removing and cleaning the battery terminals.[hr]With the battery terminal's removed clean the connection's at the starter relay then the starter.[hr]The one at the starter is the one that corrode's the most and cause's problem's like this.
Old Oct 23, 2006 | 07:53 PM
4varellis@verizon.ne's Avatar
Had the same sort of problem with my 99 Explorer. It turned out to be fowled injectors. Have you had yours cleaned lately?
Old Nov 7, 2006 | 01:38 AM
No I havent had them cleaned lately. It started running ok since then but tonight it started idling really really rough and I could feel it about to misfire while I was in the 5th gear then the check engine light starting flashing.
Firehousebikes
Apr 14, 2011 04:07 PM
Bronco76Ranger00
Nov 8, 2009 08:24 PM
jkmf250
Mar 29, 2007 05:16 PM
ncruea
Mar 10, 2007 05:06 AM
Fastronald
Nov 18, 2005 10:56 PM
