2000 XLT hard to start
Old May 7, 2009 | 06:18 PM
aeropatr82's Avatar
Default 2000 XLT hard to start
Here's my problem. When I go to start my truck (mostly when its warm) it takes a while to start. I checked the fuel pressure and it does not seem to be holding its prime. It fails the five minute leak check. FYI: This vehicle does not have a fuel pressure regulator. None of the lines appear to be leaking and vacuum lines look good. I got under the truck and found a line disconnected just aft of the tank. I could not find where it went to. One end has a little white cap on it and the other end was just dangling down. Is this a vent line? Could this be my culprit? Any help would be greatly appreciated.
Old May 7, 2009 | 06:39 PM
aeropatr82's Avatar
Ok I went and looked at another explorer and that line was just going to the left rear brake area. Hooked up to nothing as well. I guess that was not the problem. Could it be the injectors or the pump? The pump was pushing 63 psi but could it still being leaking? Any help would be greatly appreciated.
Old May 14, 2009 | 06:02 AM
aeropatr82's Avatar
I replaced pump assy., filter and fuel vapor vent valve. It fired right up. Thanks for your help.
Old Feb 17, 2017 | 06:27 AM
tipenzo's Avatar
did the fuel pump resolve the hard starting issue?
makuloco2000
Oct 22, 2013 09:46 PM
MagneMan
Feb 17, 2009 06:21 AM
98mkiv
Mar 9, 2007 04:07 PM
Ranger96
Jan 27, 2007 06:18 PM
harkkam
Dec 17, 2006 02:16 AM
