2002 Eddie Bauer edition Ford explorer 4.6 V8 over revving
Ok so I have a 2002 Eddie Bauer Ford explorer. It has the 4.6 l V8 engine with automatic 4x4, 4x4 high and 4x4 low selective options. Transmission has been rebuilt, it does not slip, and I went to the Ford dealership to make sure the transmission fluid was topped off and perfect. My problem is when I am going on a flat surface or up a small hill or downhill, everything works fine. But when I start going up a steeper Hill, I have to press the gas in More but when it downshifts, IT red lines almost as if it popped into neutral and is not in gear. it has a new torque converter, new gears, new everything. Transmission was completely rebuilt with new parts. What could my problem be?
It is an automatic 5speed with overdrive |
There have been instances when an addl pint of trans fluid into the trans helped get rid of the problem.
