2002 explorer...please help with 3 issues!! window, egg smell, and engine light
Here are the problems:
1. The passenger window does not roll up. It rolls down, but not up. It cannot be roll up from the passenger side nor the driver side. One time I took it apart and put it back and it worked, but then it failed again after a week or so. Does anyone know whats wrong? 2. My car has a nasty egg smell while in park. Its worse while driving on the freeway. Im thinking its the catalytic converter...am I right on this? I also looked up the catalytic converter for this car and its about $500 on ebay and it comes with 3 converters...is there anything cheaper or other ways? 3. My engine light also pops up. The code saids that its a gas cap. Gas cap? I have never heard of a issue where the gas cap is bad. Anyways, do I need to change this gas cap or what do I do? How do I go about getting rid of this light and issue? Thanks everyone |
RE: 2002 explorer...please help with 3 issues!! window, egg smell, and engine light
A rotten egg smell usually is a pretty good indication of a problem with the catalytic converter. The check engine light can come on if you haven't tightened the gas cap fully or not put it back on. When you do this I think it takes two cycles of filling the gas tank for the check engine to quit indicating a loose cap.
