2010 ford explorer electrical issue
I have a 2010 ford explorer and some kind of electrical problem
Thanks |
Could you please tell us how you checked the grounds?
The grounds that I found unscrewed cleaned them and screwed them back o.
From what you describe, it sounds like the instrument cluster and some other sections are using whatever path they can to get to ground.
Suggest you start at the battery negative terminal and verify each wire that goes to any ground connection is clean and good. Also sounds like you missed one or two. Make sure all the grounds going to sheet metal are good. |
