2016 Exp A/C Issues
I have a 16 Explorer XLT, the A/C is being weird. It will randomly not regularly adjust the speed on its own. I have changed the Blower Motor Resistor twice, replaced the battery also. It is still doing it. When on full blast, randomly drop speed and then go back up. Sometimes when I manually turn down the fan, it can take up to 5 minutes for the actual fan to go lower in speed. When I first changed the battery i went to leave, when accelerating the blower stopped completely and when i Braked at a light the blower kicked on. very weird. Temp is great just the fan .
Any suggestions? Thank you |
It sounds like the HVAC control module is malfunctioning.
We always check for good power and ground connections before replacing a module. If both are good, usually module replacement fixes it. |
(Post 113812)
Expensive scan tool. Probably cheaper to have capable shop verify this.
My neighbor has one. Had to get it updated didn’t show 2016 as an option. But I checked the prices on rockauto and they aren’t that bad to replace the blower motor. Now if I can find a how to video lol
