-   Ford Explorer (https://www.fordforum.com/forum/ford-explorer-20/)
-   -   2017 Ford Explorer Headlight Issue (https://www.fordforum.com/forum/ford-explorer-20/2017-ford-explorer-headlight-issue-47434/)
ADP Jul 6, 2023 11:24 AM
Someone please tell me I’m not crazy here! I’ve got a 2017 Ford Explorer Limited and within the past month I noticed that my exterior lights were no longer working according to which setting I had the control knob on. I will explain in as much detail as possible below. Before I go into that though, I wanted to mention that I took my vehicle to a local Ford dealership, and they told me there was no issue and that the lights were working as intended. I swear it’s not right and am hoping to get other opinions to either tell me I am, in fact, crazy, or that there really is an issue here (and what a fix might be if anyone knows).
Here's what’s happening. There are four settings on the exterior light control.
A. Off (Daytime Running Lights on – DRLs)
B. Parking Lamps
C. Headlamps
D. Auto Lamps
From the owner’s manual:
https://cimg7.ibsrv.net/gimg/www.for...332243e4b3.png
https://cimg9.ibsrv.net/gimg/www.for...7e253827aa.png
https://cimg2.ibsrv.net/gimg/www.for...669c0dfb73.png
Note: I have the Conventional (Non-Configurable) DRLs
When I have the vehicle in Park (P), all 4 settings work as intended. However, once I put the vehicle into any gear (Reverse, Neutral, Drive), both the Daytime Running Lamps and Headlamps are always on regardless of the control setting. This is the part that I don’t believe is correct, as the Headlamps specifically should only come on if I have the control set to either “C” – Headlamps, or “D” – Auto lamps (AND it is dark enough for the lamps to turn on). Otherwise, only the Daytime Running Lights should be on. And I know they used to work this way, up until about a month ago.
Here are pictures of what I just described:
1. Vehicle is in Park (P) and the setting is on either “A”, “B”, or “D” (and it is light enough for no Headlamps):
https://cimg7.ibsrv.net/gimg/www.for...12e138e8ff.jpg
https://cimg8.ibsrv.net/gimg/www.for...4926300ae8.jpg
2. Vehicle is in any gear (Reverse, Neutral, Drive) and the exterior light control is on any setting (including “A” - Off). Both DRLs and Headlamps are always on:
https://cimg3.ibsrv.net/gimg/www.for...3807dacd86.png
Hopefully that all makes sense. If there are questions or clarification needed, please let me know. I’m planning to try and take it to a different Ford dealership for a second opinion, but I wanted to also see if anyone else has experienced this or knew of what the issue might be. I know it’s a minor issue, but I like my vehicles to work correctly. But if I am really going crazy, please let me know, ha!
ADP Jul 12, 2023 08:27 AM
I must be crazy :D:rolleyes:
