92 explorer won't start
Which wires did you change? Previous owner of my 92 ("Dad", we call him) replaced starter, solenoid, and had alternator and battery checked for a similar problem, except it was intermittent...sometimes it would just click, and sometimes it would start normally. Turns out that it's not uncommon for the battery cable that runs down to the starter had internal corrosion...looked good on the outside, but the inside was all messed up once the insulation was cut away. Replacing all the cables fixed the problem.
birdeeshot
Jan 20, 2006 12:28 AM
birdeeshot
