93 Explorer 4x4 Grinding
Old Jan 12, 2007 | 03:00 AM
Bullfrog's Avatar
Default 93 Explorer 4x4 Grinding
Having problems with my 93 Exploder. The 4WD seems to works OK at low speeds, but if I step on it a little I hear a high pitched grinding noise coming from the front. U-joint or hubs? I jacked up the front to take the tires off and pull off the hubs. The drivers side hub had alot more grease inside than the other side. Any ideas?
Old Jan 12, 2007 | 03:13 PM
sjwoody's Avatar
Default RE: 93 Explorer 4x4 Grinding
With the experience I had with mine, I'd say it's almost certainly the u-joints at the hub (axle u-joints). To be sure, isolate by taking the front driveline off and move those joints by hand and see how they feel. You'll be able to tell if the driveline u-joints are bad. (Make sure you use alignment marks) Also, do you have manual or auto hubs? You get weird stuff happening if one of the hubs stick and stay engaged.
Old Jan 13, 2007 | 12:51 AM
Bullfrog's Avatar
Thanks SJ, I will try that this weekend. I have those WONDERFUL auto hubs and am thinking seriously about switching to manual.
nicknack24
Feb 5, 2008 10:53 PM
partyoffive
Aug 10, 2007 08:45 AM
karen travers
Dec 20, 2005 04:16 PM
spydr71
Nov 28, 2005 12:46 AM
sniper
Jul 21, 2005 03:23 AM
