94 explorer dr side window help
Driver side window will not go up or down I replaced switch twice.. new switches when I pushed driver side switch pass side window would go down in auto mode . no response from driver side window ,,,Manger at auto zone told me ford used two different switches before and after feb of 94... he did not have any access to the one prior to that date... no noise from inside door and the dome light does not dim... can anyone help?
You may have to remove the door panel to confirm power is getting to the motor on the driver's side. If it is , then there could be a problem with the motor itself.
| All times are GMT -5. The time now is 06:45 AM. |
