96 Explorer EGR Confusion
Old Jun 24, 2006 | 03:26 PM
Sygerwulf's Avatar
Default 96 Explorer EGR Confusion
Hi everyone. This is the first Ford I've owned so I'm kinda iffy on their quirks.
I've got a 96 Explorer control trac 4.0. It's running alittle rough and returning back code (can't remember number) "Insufficient EGR Flow". I've Had two
different Ford techs tell me two different things. One said it was the EGR valve or the connected lines clogged or dirty and that I should try cleaning it out
before I replace it. The other said it was the EGR Sensor. I'm wondering if this is a common problem *like the idle air control valve* and the sensors to
blame. If not I was wondering what would be the best thing to clean out the egr and lines. Would it be better to use something like intake/tb cleaner or
just compressed air? Thanks!
Old Jun 27, 2006 | 01:42 AM
Mulletman's Avatar
Default RE: 96 Explorer EGR Confusion
Common problem for that code is the DPFE sensor. I bet if you replace it, you will fix the problem. Be sure to check the hoses going to the sensor.
Old Jun 27, 2006 | 03:33 PM
drpugh's Avatar
I had the same problem with my wifes 2000 windstar. I replaced the throttle position sensor (TPS), did not work. The engine still ran rough. I then took off the IAC Idle Air Control mechanism, cleaned it with gumout and put it back on the car. The Metal piston looking part was not moving freely due to carbon buildup. This solved the problem. However, since the van had 110,000 miles on it, I chose to get a new IAC from the dealer a month later.
Hope that this helps.
drpugh
fordwoman99
Mar 3, 2013 05:24 PM
wrongnote85
Oct 11, 2010 04:48 PM
dgopetactical
May 8, 2010 01:49 PM
juangoodude
Nov 27, 2008 09:21 PM
OK_66
Jul 23, 2008 08:16 PM
