96 explorer turn signal
ok my problem is that every time i try to put on the right turn signal on by pushing the lever up it just buzzes and dosent turn on the light but if i dont lock the turn signal on it works fine any suggestions
RE: 96 explorer turn signal
do you happen to have tilt steering
yes
I just repaired the same problem on my 96 Explorer.
The grease around the contacts in the column has dried up and the contacts are corroded. You will have to remove the module, clean the contacts and lightly apply an electrical lube(grease) |
how do i go about getting the module out where is it located
| All times are GMT -5. The time now is 10:23 AM. |
