97 Expedition anti theft system
Old Feb 1, 2007 | 11:46 AM
carmenb's Avatar
Default 97 Expedition anti theft system
Hello, my Expedition will not start. It acts like the anti-theft sys is activated. The theft like blinks and it simply will not turn over. Any ideas why or how to fix it? Thanks!
Carmenb
Old Feb 1, 2007 | 12:44 PM
Default RE: 97 Expedition anti theft system
Does the system 'prove out' for normal anti-theft vehicle enabling to occur, the THEFT indicator must prove out as follows...
Normal operating prove out on the THEFT indicator is two seconds ON then OFF after the ignition switch has been cycled from OFF to RUN/START position.
If normal two second prove-out occurs and the engine cranks for more than one second after the ignition switch is turned to the START position but fails to start, the fault is not with the passive anti-theft system pre-check.
Did you try a spare key?
Other possibilities could be wiring, transceiver, control module, modue communication problems....
amarquis
Apr 23, 2008 04:54 AM
KaiZeR
May 10, 2007 06:29 AM
mrmarcgw
Sep 22, 2005 09:30 PM
mrmarcgw
Sep 15, 2005 03:31 PM
ScottGinOhio
Apr 22, 2005 01:22 PM
