-   Ford Explorer (https://www.fordforum.com/forum/ford-explorer-20/)
-   -   97 Explorer fuel pump (https://www.fordforum.com/forum/ford-explorer-20/97-explorer-fuel-pump-17983/)
Joe Feds Aug 19, 2009 07:05 PM
Where is the fuel pump located on a 97 Explorer? I think it is by the fuel tank, but I haven"t gone under there to check it out.
ford27 Aug 19, 2009 07:12 PM
hi there first off u need a special tool to disconnect the fuel lines now 4 the bad news the fuel pump is in the tank good luck
Joe Feds Aug 19, 2009 07:50 PM
is there a test I can do to see if it is bad? I'm just guessing now. It's acting like it is either now getting a spark or not getting fuel.
ford27 Aug 20, 2009 11:33 AM
if you can have some one lie under the truck and listing 4 the fuel pump to make a noise if it is making a noise then it is prob good 4 spark pull a pulg out and do the check to see if your geting spark quick turns of the key
