99 ford Explorer, xfer case and 5r55e
1 Attachment(s)
hello, i finally got to the 99 ford
explorer 4x4 with 4.0 and the 5r55e trans and bad transfer case.. > anyway i took the xfer case apart, its a borg warner > XL24-CA and this is what i > found.. > what would cause these parts to brake in the X-fer case? > Even the Xfer case clutches are > burnt,flakeing and toast. would these being burnt cause the > trans to act up as > well? > now here are the trans sypmtoms. > The engine rev's when the trans shifts, like it slips > but in all fwd gears, > but when i push the accelerator down, the trans shifts nice > and firm. I took the > pan off and it is pretty clean, I ran out of time, so > was wondering if a sol > pack, and a VB kit may correct the trans problems. > > > what do you think?? > > here is a pics of the broken parts.. also is a 5r55e trans tough to rebuild..will i need any special tools? other then spring compressors,snap ring pliers. anything i can make? thanks |
Not sure if you can get the clutch seals in on all the clutch pistons without special tools.
I remember asking a trans rebuilder shop if I could rent a 1st, reverse clutch piston seal installer tool from them for a different trans and their reply was , oh we don't replace them , they don't give much trouble. I wound up buying the plastic cone for a whopping $6.00. I guess if you take your time , you will be OK. |
